aero# cat /usr/pkg/etc/kdm/kdmrc
# KDM master configuration file
# Definition: the greeter is the login dialog, i.e., the part of KDM
# which the user sees.
# You can configure every X-display individually.
# Every display has a display name, which consists of a host name
# (which is empty for local displays specified in {Static|Reserve}Servers),
# a colon, and a display number. Additionally, a display belongs to a
# display class (which can be ignored in most cases; the control center
# does not support this feature at all).
# Sections with display-specific settings have the formal syntax
# "[X-" host [":" number [ "_" class ]] "-" sub-section "]"
# You can use the "*" wildcard for host, number, and class. You may omit
# trailing components; they are assumed to be "*" then.
# The host part may be a domain specification like ".inf.tu-dresden.de".
# It may also be "+", which means non-empty, i.e. remote displays only.
# From which section a setting is actually taken is determined by these
# rules:
# - an exact match takes precedence over a partial match (for the host part),
# which in turn takes precedence over a wildcard ("+" taking precedence
# over "*")
# - precedence decreases from left to right for equally exact matches
# Example: display name "myhost:0", class "dpy".
# [X-myhost:0_dpy] precedes
# [X-myhost:0_*] (same as [X-myhost:0]) precedes
# [X-myhost:*_dpy] precedes
# [X-myhost:*_*] (same as [X-myhost]) precedes
# [X-+:0_dpy] precedes
# [X-*:0_dpy] precedes
# [X-*:0_*] (same as [X-*:0]) precedes
# [X-*:*_*] (same as [X-*])
# These sections do NOT match this display:
# [X-hishost], [X-myhost:0_dec], [X-*:1], [X-:*]
# If a setting is not found in any matching section, the default is used.
# Every comment applies to the following section or key. Note that all
# comments will be lost if you change this file with the kcontrol frontend.
# The defaults refer to KDM's built-in values, not anything set in this file.
# Special characters need to be backslash-escaped (leading and trailing
# spaces (\s), tab (\t), linefeed (\n), carriage return (\r) and the
# backslash itself (\\)).
# In lists, fields are separated with commas without whitespace in between.
# Some command strings are subject to simplified sh-style word splitting:
# single quotes (') and double quotes (") have the usual meaning; the backslash
# quotes everything (not only special characters). Note that the backslashes
# need to be doubled because of the two levels of quoting.
[General]
# This option exists solely for the purpose of a clean automatic upgrade.
# Do not even think about changing it!
ConfigVersion=2.3
# List of permanent displays. Displays with a hostname are foreign. A display
# class may be specified separated by an underscore.
# Default is ":0"
StaticServers=:0
# List of on-demand displays. See StaticServers for syntax.
# Default is ""
ReserveServers=:1,:2,:3
# Where KDM should store its PID (do not store if empty).
# Default is ""
PidFile=/var/run/kdm.pid
# Whether KDM should lock the PID file to prevent having multiple KDM
# instances running at once. Do not change unless you are brave.
# Default is true
#LockPidFile=false
# Where to store authorization files.
# Default is "/var/run/xauth"
#AuthDir=/tmp
# Whether KDM should automatically re-read configuration files, if it
# finds them having changed.
# Default is true
#AutoRescan=false
# Additional environment variables KDM should pass on to all programs it runs.
# LD_LIBRARY_PATH and XCURSOR_THEME are good candidates;
# otherwise, it should not be necessary very often.
# Default is ""
#ExportList=LD_LIBRARY_PATH,ANOTHER_IMPORTANT_VAR
# A file KDM should read entropy from.
# Default is "/dev/mem"
#RandomFile=
# A UNIX domain socket KDM should read entropy from.
# Default is ""
#PrngdSocket=/tmp/entropy
# A TCP socket on localhost KDM should read entropy from.
# Default is 0
#PrngdPort=4840
# A character device KDM should read entropy from.
# Empty means use the system's preferred entropy device.
# Default is ""
#RandomDevice=/dev/altrandom
# Where the command FiFos should be created; make it empty to disable
# them.
# Default is "/var/run/xdmctl"
#FifoDir=/tmp
# The group to which the global command FiFo should belong;
# can be either a name or a numerical ID.
# Default is 0
#FifoGroup=xdmctl
# The directory in which KDM should store persistent working data.
# Default is "/var/lib/kdm"
#DataDir=
# The directory in which KDM should store users' .dmrc files. This is only
# needed if the home directories are not readable before actually logging in
# (like with AFS).
# Default is ""
#DmrcDir=/nfs-shared/var/dmrcs
[Xdmcp]
# Whether KDM should listen to incoming XDMCP requests.
# Default is true
Enable=false
# The UDP port on which KDM should listen for XDMCP requests. Do not change.
# Default is 177
#Port=177
# File with the private keys of X-terminals. Required for XDM authentication.
# Default is ""
#KeyFile=/usr/pkg/share/kde/config/kdm/kdmkeys
# XDMCP access control file in the usual XDM-Xaccess format.
# Default is "/usr/pkg/share/kde/config/kdm/Xaccess"
#Xaccess=
# Number of seconds to wait for display to respond after the user has
# selected a host from the chooser.
# Default is 15
#ChoiceTimeout=10
# Strip domain name from remote display names if it is equal to the local
# domain.
# Default is true
#RemoveDomainname=false
# Use the numeric IP address of the incoming connection on multihomed hosts
# instead of the host name.
# Default is false
#SourceAddress=true
# The program which is invoked to dynamically generate replies to XDMCP
# DirectQuery or BroadcastQuery requests.
# If empty, no program is invoked and "Willing to manage" is sent.
# Default is ""
Willing=/usr/pkg/share/kde/config/kdm/Xwilling
[Shutdown]
# The command (subject to word splitting) to run to halt the system.
# Default is "/sbin/shutdown -h now"
HaltCmd=/sbin/shutdown -p now
# The command (subject to word splitting) to run to reboot the system.
# Default is "/sbin/shutdown -r now"
RebootCmd=/sbin/shutdown -r now
# Whether it is allowed to shut down the system via the global command FiFo.
# Default is false
#AllowFifo=true
# Whether it is allowed to abort active sessions when shutting down the
# system via the global command FiFo.
# Default is true
#AllowFifoNow=false
# The boot manager KDM should use for offering boot options in the
# shutdown dialog.
# "None" - no boot manager
# "Grub" - Grub boot manager
# "Lilo" - Lilo boot manager (Linux on i386 & x86-64 only)
# Default is None
#BootManager=Grub
# Rough estimations about how many seconds KDM will spend at most on
# - opening a connection to the X-server (OpenTime) if the attempt
# - times out: OpenTimeout
# - is refused: OpenRepeat * OpenDelay
# - starting a local X-server (ServerTime):
# ServerAttempts * (ServerTimeout + OpenDelay)
# - starting a display:
# - local display: ServerTime + OpenTime
# - foreign display: StartAttempts * OpenTime
# - XDMCP display: OpenTime (repeated indefinitely by client)
# Core config for all displays
[X-*-Core]
# How long to wait before retrying to connect a display.
# Default is 15
#OpenDelay=15
# How long to wait before timing out a display connection attempt.
# Default is 120
#OpenTimeout=120
# How many connection attempts to make during a start attempt. Note that
# a timeout aborts the entire start attempt.
# Default is 5
#OpenRepeat=5
# Try at most that many times to start a display. If this fails, the display
# is disabled.
# Default is 4
#StartAttempts=4
# Ping remote display every that many minutes.
# Default is 5
#PingInterval=5
# Wait for a Pong that many minutes.
# Default is 5
#PingTimeout=5
# The name of this X-server's Xauth file.
# If empty, a random name in the AuthDir directory will be used.
# Default is ""
#AuthFile=
# Specify a file with X-resources for the greeter, chooser and background.
# The KDE frontend does not use this file, so you do not need it unless you
# use another background generator than krootimage.
# Default is ""
#Resources=
# The xrdb program to use to read the above specified recources.
# Subject to word splitting.
# Default is "/usr/X11R6/bin/xrdb"
#Xrdb=
# A program to run before the greeter is shown. Can be used to start an
# xconsole or an alternative background generator. Subject to word splitting.
# Default is ""
Setup=/usr/pkg/share/kde/config/kdm/Xsetup
# A program to run before a user session starts. Subject to word splitting.
# Default is ""
Startup=/usr/pkg/share/kde/config/kdm/Xstartup
# A program to run after a user session exits. Subject to word splitting.
# Default is ""
Reset=/usr/pkg/share/kde/config/kdm/Xreset
# The program which is run as the user which logs in. It is supposed to
# interpret the session argument (see SessionsDirs) and start an appropriate
# session according to it. Subject to word splitting.
# Default is "/usr/X11R6/bin/xterm -ls -T"
Session=/usr/pkg/share/kde/config/kdm/Xsession
# The program to run if Session fails.
# Default is "/usr/X11R6/bin/xterm"
#FailsafeClient=
# The PATH for the Session program.
# Default is "/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/usr/games"
#UserPath=
# The PATH for Setup, Startup and Reset, etc.
# Default is "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/X11R6/bin"
#SystemPath=
# The default system shell.
# Default is "/bin/sh"
#SystemShell=/bin/bash
# Where to put the user's X-server authorization file if ~/.Xauthority
# cannot be created.
# Default is "/tmp"
#UserAuthDir=
# Whether to automatically restart sessions after X-server crashes.
# Note that enabling this makes circumventing screen lockers other than
# KDE's built-in one possible!
# Default is false
#AutoReLogin=true
# Allow root logins?
# Default is true
AllowRootLogin=false
# Allow to log in, when user has set an empty password?
# Default is true
AllowNullPasswd=false
# Who is allowed to shut down the system. This applies both to the
# greeter and to the command FiFo.
# "None" - no "Shutdown..." menu entry is shown at all
# "Root" - the root password must be entered to shut down
# "All" - everybody can shut down the machine
# Default is All
AllowShutdown=Root
# Who is allowed to abort active sessions when shutting down.
# "None" - no forced shutdown is allowed at all
# "Root" - the root password must be entered to shut down forcibly
# "All" - everybody can shut down the machine forcibly
# Default is All
#AllowSdForceNow=Root
# The default choice for the shutdown condition/timing.
# "Schedule" - shut down after all active sessions exit (possibly at once)
# "TryNow" - shut down, if no active sessions are open; otherwise, do nothing
# "ForceNow" - shut down unconditionally
# Default is Schedule
#DefaultSdMode=ForceNow
# How to offer shutdown scheduling options:
# "Never" - not at all
# "Optional" - as a button in the simple shutdown dialogs
# "Always" - instead of the simple shutdown dialogs
# Default is Never
#ScheduledSd=Optional
# The directories containing session type definitions in .desktop format.
# Default is "/usr/pkg/share/kde/apps/kdm/sessions"
#SessionsDirs=/etc/X11/sessions,/usr/share/xsessions
# The file (relative to $HOME) to redirect the session output to. This is
# a printf format string; one %s will be replaced with the display name.
# Default is ".xsession-errors"
ClientLogFile=.xsession-errors-%s
# Whether KDM's built-in utmp/wtmp/lastlog registration should be used.
# Default is true
#UseSessReg=false
# Greeter config for all displays
[X-*-Greeter]
# Widget style of the greeter. "" means the built-in default which currently
# is "Plastik".
# Default is ""
#GUIStyle=Windows
# Widget color scheme of the greeter. "" means the built-in default which
# currently is yellowish grey with some light blue and yellow elements.
# Default is ""
#ColorScheme=Pumpkin
# What should be shown in the greeter's logo are:
# "None" - nothing
# "Logo" - the image specified by LogoPixmap
# "Clock" - a neat analog clock
# Default is Clock
LogoArea=Logo
# The image to show when LogoArea=Logo.
# Default is ""
LogoPixmap=/usr/pkg/share/kde/icons/NetBSD-flag.png
# The relative coordinates (X,Y in percent) of the center of the greeter.
# Default is "50,50"
#GreeterPos=30,40
# The screen the greeter should be displayed on in multi-headed and Xinerama
# setups. The numbering starts with 0. For Xinerama, it corresponds to the
# listing order in the active ServerLayout section of XF86Config; -1 means
# to use the upper-left screen, -2 means to use the upper-right screen.
# Default is 0
#GreeterScreen=-1
# The headline in the greeter. The following character pairs are replaced:
# - %d -> current display
# - %h -> host name, possibly with domain name
# - %n -> node name, most probably the host name without domain name
# - %s -> the operating system
# - %r -> the operating system's version
# - %m -> the machine (hardware) type
# - %% -> a single %
# Default is "Welcome to %s at %n"
#GreetString=K Desktop Environment (%n)
# Whether the fonts used in the greeter should be antialiased.
# Default is false
#AntiAliasing=true
# The font for the greeter headline.
# Default is "Serif,20,bold"
#GreetFont=Serif,20,5,0,50,0
# The normal font used in the greeter.
# Default is "Sans Serif,10"
#StdFont=Sans Serif,10,5,0,50,0
# The font used for the "Login Failed" message.
# Default is "Sans Serif,10,bold"
#FailFont=Sans Serif,10,5,0,75,0
# What to do with the Num Lock modifier for the time the greeter is running:
# "Off" - turn off
# "On" - turn on
# "Keep" - do not change the state
# Default is Keep
#NumLock=Off
# Language and locale to use in the greeter, encoded like $LC_LANG.
# Default is "en_US"
#Language=de_DE
# Enable autocompletion in the username line edit.
# Default is false
#UserCompletion=true
# Enable user list (names along with images) in the greeter.
# Default is true
#UserList=false
# User selection for UserCompletion and UserList:
# "NotHidden" - all users except those listed in HiddenUsers
# "Selected" - only the users listed in SelectedUsers
# Default is NotHidden
#ShowUsers=Selected
# For ShowUsers=Selected. @<group> means all users in that group.
# Default is ""
#SelectedUsers=root,johndoe
# For ShowUsers=NotHidden. @<group> means all users in that group.
# Default is ""
#HiddenUsers=root
# Special case of HiddenUsers: users with a non-zero UID less than this number
# will not be shown as well.
# Default is 0
MinShowUID=1000
# Complement to MinShowUID: users with a UID greater than this number will
# not be shown as well.
# Default is 65535
MaxShowUID=65000
# If false, the users are listed in the order they appear in /etc/passwd.
# If true, they are sorted alphabetically.
# Default is true
#SortUsers=false
# Specify, where the users' pictures should be taken from.
# "AdminOnly" - from <FaceDir>/$USER.face[.icon]
# "PreferAdmin" - prefer <FaceDir>, fallback on $HOME
# "PreferUser" - ... and the other way round
# "UserOnly" - from the user's $HOME/.face[.icon]
# Default is AdminOnly
#FaceSource=PreferUser
# The directory containing the user images if FaceSource is not UserOnly.
# Default is "/usr/pkg/share/kde/apps/kdm/faces"
#FaceDir=/usr/share/faces
# Specify, if/which user should be preselected for log in.
# "None" - do not preselect any user
# "Previous" - the user which successfully logged in last time
# "Default" - the user specified in the DefaultUser option
# Default is None
#PreselectUser=Previous
# If this is true, the password input line is focused automatically if
# a user is preselected.
# Default is false
#FocusPasswd=true
# The password input fields cloak the typed in text. Specify, how to do it:
# "OneStar" - <literal>*</literal> is shown for every typed letter
# "ThreeStars" - <literal>***</literal> is shown for every typed letter
# "NoEcho" - nothing is shown at all, the cursor does not move
# Default is OneStar
#EchoMode=NoEcho
# If true, krootimage will be automatically started by KDM; otherwise, the
# Setup script should be used to setup the background.
# Default is true
#UseBackground=false
# The configuration file to be used by krootimage.
# Default is "/usr/pkg/share/kde/config/kdm/backgroundrc"
#BackgroundCfg=
# Hold the X-server grabbed the whole time the greeter is visible. This
# may be more secure, but it will disable any background and other
# X-clients started from the Setup script.
# Default is false
#GrabServer=true
# How many seconds to wait for grab to succeed.
# Default is 3
#GrabTimeout=3
# Warn, if display has no X-authorization (local auth cannot be created,
# XDMCP display wants no auth, or display is foreign from StaticServers).
# Default is true
#AuthComplain=false
# Random seed for forging saved session types, etc. of unknown users.
# This value should be random but constant across the login domain.
# Default is 0
ForgingSeed=1141165679
# Specify conversation plugins for the login dialog. Each plugin can be
# specified as a base name (which expands to $kde_modulesdir/kgreet_$base)
# or as a full pathname.
# Default is "classic"
#PluginsLogin=sign
# Same as PluginsLogin, but for the shutdown dialog.
#PluginsShutdown=modern
# A list of options of the form Key=Value. The conversation plugins can query
# these settings; it is up to them what possible keys are.
# Default is ""
#PluginOptions=SomeKey=randomvalue,Foo=bar
# Show the "Console Login" action in the greeter (if ServerTTY/ConsoleTTYs
# is configured).
# Default is true
#AllowConsole=false
# A program to run while the greeter is visible. It is supposed to preload
# as much as possible of the session that is going to be started (most
# probably).
# Default is ""
Preloader=/usr/pkg/bin/preloadkde
# Whether the greeter should be themed.
# Default is false
#UseTheme=true
# The theme to use for the greeter. Can point to either a directory or an XML
# file.
# Default is ""
Theme=/usr/pkg/share/kde/apps/kdm/themes/circles
# Core config for local displays
[X-:*-Core]
# How often to try to run the X-server. Running includes executing it and
# waiting for it to come up.
# Default is 1
#ServerAttempts=1
# How long to wait for a local X-server to come up.
# Default is 15
#ServerTimeout=15
# The command line to start the X-server, without display number and VT spec.
# This string is subject to word splitting.
# Default is "/usr/X11R6/bin/X -br"
ServerCmd=/usr/X11R6/bin/X -br
# Additional arguments for the X-servers for local sessions.
# Default is ""
ServerArgsLocal=-nolisten tcp vt05
# Additional arguments for the X-servers for remote sessions.
# Default is ""
#ServerArgsRemote=
# Restart instead of resetting the local X-server after session exit.
# Use it if the server leaks memory etc.
# Default is false
#TerminateServer=true
# The signal needed to reset the local X-server.
# Default is 1 (SIGHUP)
#ResetSignal=1
# The signal needed to terminate the local X-server.
# Default is 15 (SIGTERM)
#TermSignal=15
# Create X-authorizations for local displays.
# Default is true
#Authorize=false
# Which X-authorization mechanisms should be used.
# Default is "MIT-MAGIC-COOKIE-1"
#AuthNames=
# Need to reset the X-server to make it read initial Xauth file.
# Default is false
#ResetForAuth=true
# See above
AllowNullPasswd=true
# See above
AllowShutdown=All
# Enable password-less logins on this display. USE WITH EXTREME CARE!
# Default is false
#NoPassEnable=true
# The users that do not need to provide a password to log in. NEVER list root!
# "*" means all non-root users. @<group> means all users in that group.
# Default is ""
#NoPassUsers=fred,ethel
# Greeter config for local displays
[X-:*-Greeter]
# See above
# See above
FocusPasswd=true
# Specify whether the greeter of local displays should start up in host chooser
# (remote) or login (local) mode and whether it is allowed to switch to the
# other mode.
# "LocalOnly" - only local login possible
# "DefaultLocal" - start up in local mode, but allow switching to remote mode
# "DefaultRemote" - ... and the other way round
# "RemoteOnly" - only choice of remote host possible
# Default is LocalOnly
LoginMode=DefaultLocal
# A list of hosts to be automatically added to the remote login menu. The
# special name "*" means broadcast.
# Default is "*"
#ChooserHosts=*,ugly,sky,dino,kiste.local,login.crap.com
# Show the "Restart X Server"/"Close Connection" action in the greeter.
# Default is true
AllowClose=false
# Core config for 1st local display
[X-:0-Core]
# The TTY line (without /dev/) the X-server covers physically.
# Default is ""
ServerTTY=
# Enable automatic login. USE WITH EXTREME CARE!
# Default is false
#AutoLoginEnable=true
# If true, auto-login after logout. If false, auto-login is performed only
# when a display session starts up.
# Default is false
#AutoLoginAgain=true
# The delay in seconds before automatic login kicks in.
# Default is 0
#AutoLoginDelay=10
# The user to log in automatically. NEVER specify root!
# Default is ""
#AutoLoginUser=fred
# The password for the user to log in automatically. This is NOT required
# unless the user is logged into a NIS or Kerberos domain. If you use this
# option, you should "chmod 600 kdmrc" for obvious reasons.
# Default is ""
#AutoLoginPass=secret!
# Immediately lock the automatically started session. This works only with
# KDE sessions.
# Default is false
#AutoLoginLocked=true
# See above
# Greeter config for 1st local display
[X-:0-Greeter]
# See above
#PreselectUser=Default
# The user to preselect if PreselectUser=Default.
# Default is ""
#DefaultUser=johndoe
aero#
